Puissance Min: 8 / Max: 10 kW
Rendement: 77.7 %
de Contura
52 / 52T de Contura
Puissance Min: 3 / Max: 9 kW
Aire 7 de Charnwood
Sofia 6/8 de France Turbo
Puissance Max: 7.5 kW
Rendement: 77 %
Puissance Nominale: 5.5 kW
de VermontCasting
Federal de VermontCasting
Puissance Max: 13 kW
Rendement: 78.4 %
ZK60 de De Manincor
Puissance Nominale: 18.5 kW
de Thermorossi
Insert 490 line de Thermorossi
Puissance Min: 3.1 / Nominale: 8.5 kW
Rendement: 89.1 %
Arianna 8 de Interstoves
Puissance Nominale: 7.4 kW
Rendement: 91.2 %
Aladino 13 de MorettiDesign
Rendement: 86.8 %
Murano de Interstoves
Rendement: 88.7 %
P-10 de Stûv
Tonda Plus de Ungaro
Rendement: 90.4 %
