de Attika
Art-10 de Attika
Puissance Min: 3 / Max: 10 kW
Rendement: 81.4 %
Aire 7 de Charnwood
Puissance Nominale: 5.5 kW
Puissance Max: 8 kW
Rendement: 85.2 %
de Lotus
living de Lotus
Puissance Min: 3 / Max: 9 kW
Rendement: 80.5 %
Z60F de De Manincor
Puissance Max: 16 kW
Rendement: 85 %
Arianna 6 de Interstoves
Puissance Nominale: 6.2 kW
Rendement: 91.2 %
Fabio 20 de Interstoves
Rendement: 95.1 %
de Freepoint
Flute de Freepoint
Puissance Min: 2.4 / Nominale: 6.5 kW
Rendement: 91.3 %
Compact 8 de MorettiDesign
Rendement: 87.5 %
Liby de Ungaro
Rendement: 92.2 %
